Issues with a new install
COW Forums : Media 100
noah wight
on Apr 28, 2016 at 8:15:17 pm
So I installed the newest version of Media100 on my new iMac. I'm trying to get the workflow dialed but running into an odd issue. Comp clips that I create in Boris on the video line look like the image below. They render correctly but low quality which I suspect is just a quality settings issue. if i do the same in the title track there is no issue and they look fine. The results are the same regardless of whether 601 4x3 or 1080i. The process is nothing special and I have done it a million times with the same images and process on my other system. Just created new Comp clip in the video timeline and then in Boris added new media> still image and psd doc over solid color track. Apply changes and the top part of the image in the record window is the squished image i'm using with the scrambled artifacts of other images from previous attempts at the bottom. Any ideas?
Noah Wight
CBTV Inc/ESProductions
Crested Butte, CO 81224
noah wight
Re: Issues with a new install
on Apr 28, 2016 at 10:37:12 pm
Never mind. Handled. Had to install Prores codecs and get away from Motion Jpeg B.
Noah Wight
