Codecs Media 100 after installing 2.1.7
COW Forums : Media 100
Cornelis van Liempd
on Jan 20, 2016 at 7:34:00 pm
My list of codecs are gray after installing 2.1.7
I only can select Motion JPEG B. It is black.
I cannot select: Apple pro res 422, 422HQ, 422LT,etc.
What is wrong.
Cornelis van Liempd
Nederland.
Jon Kozenko
Re: Codecs Media 100 after installing 2.1.7
on Jan 21, 2016 at 9:12:34 pm
Hello Cornelis,
Media 100 would be able to use these Codecs, but it doesn't install them. If you have access to another system that has these Codecs (your own system or someone else's), you should be able to copy them from that system to this one. The location that these Components would be is here -
Macintosh HD :: Library :: Quicktime
If you are unable to access a system with these Codecs/Components, you might be able to download them somewhere. Primarily what you would be looking for are the Apple Quicktime Components.
Thank you.
Jon
Cornelis van Liempd
on Jan 22, 2016 at 8:17:17 am
Thanks,I did it.
Also ref. to https://forums.creativecow.net/thread/4/865993
Cornelis
