M100 codecs
COW Forums : Media 100
Jim Jorstad
M100 codecs
on Jun 13, 2015 at 5:24:59 am
Since upgrading to version 2.6 M100, my question is this. I would like to shoot with a Canon C100 married to a Atomos Ninja 2. If I shot in 1080p 24, what program codec shall I use. I the closest one I see in M100 is 1080psf24 which I believe is different than the traditional 1080p24. Can someone illuminate us on this? Or should I just stick with 1080 29.97 as a back up?
Jim Wiseman
Re: M100 codecs
on Jun 18, 2015 at 12:29:27 am
I've used the HD 1080psf 23.98 fps 48Khz timeline for EX1 Sony (psf) and true 23.98 progressive and it has worked for me. I haven't worked with files from your setup. but I believe that should work. I typically convert everything to ProRes 422 or 422HQ.
Jim Wiseman
Sony PMW-EX1, Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Pro X 10.2.1, Final Cut Studio 2 and 3, Media 100 Suite 2.1.6, Premiere Pro CS 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Blackmagic Ultrastudio 4K, Blackmagic Teranex, Avid MC, 2013 Mac Pro Hexacore, 1TB SSD, 64GB RAM, 2-D500, Helios 2 w 2-960GB SSDs: 2012 Hexacore MacPro 3.33 Ghz, 24Gb RAM, GTX-680, 960GB SSD: Macbook Pro 17" 2011 2.2 Ghz Quadcore i7 16GB RAM 250GB SSD
