Media 100 and 4k
COW Forums : Media 100
Gerry Condez
Media 100 and 4k
on Feb 8, 2015 at 4:49:33 pm
Im using kona 3g. Are the 4k files can only be imported? Can it be Acquired through sdi? Thanks
Floh Peters
Re: Media 100 and 4k
on Feb 9, 2015 at 5:20:55 pm
SDI input is only possible for HD (and of course SD) resolutions right now
Gerry Condez
on Feb 10, 2015 at 11:04:49 pm
Thanks Floh,
Just to clear my question again with the format. So, HD is the regular HD at 1920x1080? Is that right? So I can only import 4K files, edit and whats next? Can I monitor them in regular HD monitor? Does Kona convert 4k to HD playback? thanks
Floh Peters
on Feb 11, 2015 at 10:38:46 am
You can monitor in HD (1080) via HD-SDI, and of course you can export as a file in 4k
