Could not complete “Export” command
COW Forums : Media 100
Charlie Atlas
on Oct 29, 2013 at 4:01:13 am
I get the message "Could not complete “Export” command because you do not have the necessary access privileges" when i try to export certain timelines. Other timelines work fine. Does anyone have any ideas what is causing this? I have never had any problem like this before. I am running M100 Suite 2.1.2 on Mac OS X 10.8.5
Charlie_A
Dave Simpson
Re: Could not complete “Export” command
on Oct 30, 2013 at 5:36:52 pm
Hello Charlie, Is it the longer timelines that give you the error? If the drive is formatted as FAT32 then the maximum file size is 4gigs, so even if you have tons or room left you can't create a single file bigger than 4gigs.
If the drive is HFS then you won't run into this limitation.
cheers
Dave
