XAVC import
COW Forums : Media 100
Mark Mooney
XAVC import
on Oct 24, 2013 at 2:12:41 am
Hi everyone..
I just purchased the Sony F5 . The codec is Xavc .. I know that media 100 will not import .. But I am converting to ProRes and then importing.. For some reason .. Media100 is importing as 1080i instead of 1080p I Mac shooting 29.97.. Any suggestions .. Or ideas.. Wish there was a way to go in XAVC..
Mark
Floh Peters
Re: XAVC import
on Oct 24, 2013 at 11:58:58 am
[Mark Mooney] "But I am converting to ProRes and then importing.. "
How are you converting into ProRes? In the ProRes codec, there is a flag for interlaced/progressive. So the software doing the conversion writes the files as ProRes interlaced, which gets read by Media 100. You should check the settings of your conversion software.
Mark Mooney
Re: XAVC import
on Oct 27, 2013 at 2:47:14 am
Thanks Floh ..
Using a software called ideal share.. Seems to work fine .. But when I import ..it is 1080i. If I change the import settings in M_100 to use media standard .. It rendered the file to progressive .. But with blacks crushed and gamma down.
The 1080i file plays fine and looks good on a 1080p timeline .. But is awkward workflow with the processor switching between interlaced and progressive between the bin and timeline each time..
Need to find a way to convert the XVAC to ProRes that M100 will except 29.97p.
Thanks for watching our back Floh!
Mark
