HDV Capture issues
COW Forums : Media 100
Marcus Warren
HDV Capture issues
on Oct 17, 2013 at 3:58:07 am
I am having problems capturing HDV video shot in 60i on a Canon XH-A1. I have tried capturing on a 15" MacBookPro and a 21.5" iMac, both with 4 GB RAM and Media 100 Suite 2.1.
I noticed in setting up for capture that there is not an HDV 1080 60i option; HDV 1080 29.97 is the only option. When I try to capture I repeatedly get the Temporary Loss of Video Sync warning and no video in the monitor.
Deferred capture makes no difference.
I can capture in SD, but not HDV. What am I doing wrong?
Both computers run very sluggishly when the A1 is attached (via Firewire). They even run sluggishly even when the attached A1 is not playing video. Very strange. I need to capture the footage in a few hours because I have to return the camera.
I guess I could capture in SD and transcode to HD but I would rather not do that. I have tried to capture to two different hard drives as well, but no luck.
Robert Stone
Re: HDV Capture issues
on Oct 17, 2013 at 7:12:06 am
Aloha Marcus - On your camera, make sure your output is set to HDV and that down conversion is off. That's in the SIGNAL SETUP menu.
Blessings,
Robert C. Stone
http://HippieFilm.com
http://MauiTVSpots.com
Robert Stone
on Oct 17, 2013 at 7:18:13 am
Also - I'm assuming that you chose ProRes codec for HD and Video Input is HD Firewire HDV? The ProRes codec should be less strain on your system than trying to CODE/DECODE HDV. Eliminates the long GOPs.
HTH
Robert C. Stone
Marcus Warren
on Oct 19, 2013 at 4:37:27 pm
Hi Robert, I had indeed done all that you suggested before I posted. Interestingly, I went and shot test footage in 30f and 24f and they captured with no issues, so I shot additional test footage at 60i and it captured with no problems. So I went back to the original tape and uploaded it with no further issues. I have no idea what changed, but as I mentioned in the first post I initially tried two different computers with two different licensed installs of M100 Suite and it just flat wouldn't work.
Thanks for taking the time to troubleshoot with me.
Robert Stone
on Oct 19, 2013 at 4:56:19 pm
Aloha Marcus - sometimes MAGIC HAPPENS! Glad it worked out!
Blessings,
Robert C. Stone
