Multi-clip editing sound
COW Forums : Media 100
jim brodie
on Oct 2, 2013 at 12:50:42 pm
Hi Flo,
Thank you for your tutorial. Its been awhile since I've done this but I have two cameras one with the good sound and one with the camera mike guide track. What is the most efficient way to cut between cameras without simultaneously switching between the good audio on Cam#1 and the inferior audio on Cam#2 Do I have to strip out the good audio as a third element before I form a multiclip for each segment? Each time I Ctrl-F6 I'm switch between the good audio and bad audio. Can I adjust that?
Thank you for your help.
Jim
Robert Stone
Re: Multi-clip editing sound
on Oct 2, 2013 at 4:10:40 pm
Aloha Jim - go to your Media 100 preferences menu and check under Multiclip. You can change the activator keys to just cut video, not audio. I don't have the program open right now, but try that first!
Blessings,
Robert C. Stone
http://HippieFilm.com
http://MauiTVSpots.com
