Renaming Batch Export Items?
COW Forums : Media 100
Jaeson Koszarsky
on Aug 28, 2013 at 5:21:23 pm
I have 20 ads in a single program. If I add each to the batch export, Media100 gives them all the same name. Can I rename the entries in the queue?
Jaeson
Floh Peters
Re: Renaming Batch Export Items?
on Aug 29, 2013 at 4:35:08 pm
Hmmm, if you want to do a batch export (range), you cannot do that in a single pass anyway, since the batch export window will look at your set range on your timeline when you press the "start" button in the export window, as far as I know…
Jaeson Koszarsky
on Aug 29, 2013 at 5:56:39 pm
I wondered about that. It would be great if the queue item could remember the range that existed when it was added to the queue and be given a user-definable name.
Jaeson
