How to export audio?
COW Forums : Media 100
Martijn Beekers
on Jun 15, 2013 at 9:05:53 am
Hi, I'm a sound engineer trying to find a way to export my client's audio directly from his Media100 rig. I want to use the XML export feature without having to import into FCP and export it from there, because this way you loose too much information about levels, automation and such. On top of that a lot of clips are out of sync once they are imported into Nuendo.
I want to be able to export an XML, import it into AATranslator and export it to Nuendo. That part is working. The only thing I need is the actual media used in the project. How does one do that? Is there any way of consolidating the audio used in the project? If so, please enlighten me!
Thanks a lot,
Martijn Beekers
The Sound Post Netherlands
