AVI file
COW Forums : Media 100
Gerry Condez
AVI file
on Jun 11, 2013 at 9:26:24 pm
How to get .avi files to media 100? Is there a converter that I can use? Thanks
Check out the camera support I designed at
http://camerasupportbracket.com
Jaeson Koszarsky
Re: AVI file
on Jun 13, 2013 at 8:27:34 pm
Will Media100 import the AVI if you change the IMPORT TYPE file filter to ALL?
You could try FLV crunch if you want to convert files outside of M100.
http://download.cnet.com/Flv-Crunch/3000-2194_4-10909295.html
We use Sorenson Squeeze but it's a little more expensive.
Jaeson
Gary Milligan
Re: AVI file
on Jun 14, 2013 at 6:09:43 pm
MPEG Streamclip (free) will convert - at least it worked for me when I did a quick test a few minutes ago.
HTH
Gary
Gerry Condez
Re: AVI file
on Jun 14, 2013 at 10:45:08 pm
Thanks you guys. If you dont do that file often, you forget. I appreciate the help.
groot james
Re: AVI file
on Jun 17, 2013 at 3:11:39 am
Simply convert the file to a more common format like mp4.
I used AppGeeker for a while, it wasn't that bad, never had any problems with it.
http://www.appgeeker.com/how-to/convert-avi-to-mp4-mac.html
" Everything in this world has a loophole.....you just need to find the right one ! "
