Anyone updated to 2.1.3?
COW Forums : Media 100
Jim Wiseman
on Apr 17, 2013 at 8:17:54 pm
Anyone updated to 2.1.3? If so, how is it performing?
Jim Wiseman
Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17" 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
jeremy Rowell
Re: Anyone updated to 2.1.3?
on Apr 17, 2013 at 9:03:09 pm
I have "Updated". I can see no difference. Everything is working ok.
Jim Wiseman
on Apr 17, 2013 at 9:24:17 pm
Thanks. Glad to see they are keeping up to date with new I/O hardware and OSX system software.
Jim Wiseman
Floh Peters
on Apr 18, 2013 at 11:54:27 am
Yep, not much happened except support for the new hardware (which of course is great). Have been working with it for a couple of weeks without (new) issues.
Jaeson Koszarsky
on Apr 18, 2013 at 4:21:17 pm
I was hoping to see the "exiting from RED freeze" bug get fixed. I find myself force quitting M100 daily. It happens on both our MacPro systems.
Jaeson
Jaeson Koszarsky
on Apr 18, 2013 at 8:53:54 pm
What version of AJA driver is needed for Suite 2.1.3? I didn't read anything in the release notes that mentions needing to update. So I installed 2.1.3, it went ok. Launched Media100 and was greeted with:
"Could not start the application because an incompatibility with the AJA hardware driver was detected."
For AJA, I'm currently using 10.3.2 with KONA LHi. I see v10.4.4 on the AJA website. Is that supported by Suite2.1.3?
Jaeson
Floh Peters
on Apr 18, 2013 at 9:25:34 pm
Yes, Aja 10.4.4 drivers are supported.
Jaeson Koszarsky
on Apr 18, 2013 at 9:54:19 pm
Thanks again Floh. The 10.4.4 drivers worked.
Bob Slenker
on Apr 21, 2013 at 3:21:38 am
I upgraded today on a MacBook Pro and oddly now the app won't work. It opens but goes straight to the "About" window showing the registration info. All other controls are grayed out and I can't even close the app without a force-quit. I will say that the "About-Registration" panel was the last thing I had open in my previous version. I was looking at the product ID and unlock code wondering if upgrading would require a new one.
I was running Lion but encountered this issue so afterwards, today I upgraded to Mountain Lion wondering if that had anything to do with it. Sadly, no.
Jaeson Koszarsky
on Apr 21, 2013 at 12:38:50 pm
I don't know if this is what's happening in your situation, but I've gotten stuck with OpenOffice several times after launching the app and needed to delete the "saved state" information before I could use it again.
In this case, I need to hold OPTION key, go to the GO menu, and select LIBRARY. Then look for the SAVED APPLICATION STATE folder. In there would be a file like org.openoffice.script.savedState that needs deleted.
I've not had this ever happen with Media100. But if I did, it would be something I'd try.
Jaeson
Bob Slenker
on Apr 21, 2013 at 11:12:47 pm
Thanks Jaeson.
i did that. it might have helped. not sure. the app still opened the same way but this time i simply clicked in the license key box where the license key was already listed and i just hit enter and the window closed, opening up the rest of the windows and allowing the app to function properly. chances are i am an idiot and that was all i needed to do. =)
Bob
