TimeFX Broken?
COW Forums : Media 100
Jaeson Koszarsky
TimeFX Broken?
on Mar 20, 2013 at 4:41:33 pm
Any hints on getting TimeFX to work in Media100 Suite 2.1.2?
I currently trying to reverse a clip, without any luck. It looks ok until the actual render occurs.
I've had difficulties with speed adjustments in TimeFX too.
Jaeson
Jim Downey
Re: TimeFX Broken?
on Mar 22, 2013 at 6:45:15 am
Hi Jaeson, I haven't had any problems with M100 v2.1.2 but with my 844X my timeFX would never work - I did have the occasional win by zooming out the timeline before rendering. May help.
Michael Slowe
Re: TimeFX Broken?
on Mar 22, 2013 at 10:06:07 am
Jaeson, tested my slo-mo in Media 100 2.1.2 with OS 10.8.2 and it worked.
Michael Slowe
Gregg Michaels
Re: TimeFX Broken?
on Mar 22, 2013 at 1:50:14 pm
This bug has been around for a couple of years now, and I believe it still exists. (Not sure if it's the same you're experiencing) After you create a TimeFx change to a clip, you have to hit apply before rendering. If you just type in a TimeFX speed and then hit render or just move on with the edit without hitting apply, I believe you get a freeze frame of either the beginning or end of the clip when it eventually gets rendered.
GM
