Slowmotion rendering
COW Forums : Media 100
Gerry Condez
on Oct 22, 2012 at 12:52:05 pm
Hi, Had a project last week which required slow motion FX. All of the clips with slow motion started and ended with a freeze frame upon rendering. So all the clips with FX and a dissolve had problems. Any idea what caused those? Media100 2.1.1 / OS 10.7.4
Floh Peters
Re: Slowmotion rendering
on Oct 22, 2012 at 12:56:59 pm
Usually this happens if you lengthen a slomo clip in a timeline. You have to make sure that you include the area you need before either hitting apply after changing the speed in the edit suite or before dragging the clip from the Edit Suite to the timeline.
