Media100 XML
COW Forums : Media 100
Gerry Condez
Media100 XML
on Aug 27, 2012 at 12:35:25 am
Is the media100 XML file can be imported to final cut x?
Floh Peters
Re: Media100 XML
on Aug 28, 2012 at 10:42:59 am
FCP7 XML and FCP X XML are completely different. FCP7 cannot read FCP-X XML and vice versa. Media 100 does export FCP7 XML. But there is a tool that can convert between the formats. I havenĀ“t tested it with Media100 XMLs, though.
Gerry Condez
Re: Media100 XML
on Aug 30, 2012 at 5:04:31 am
Thanks Floh,
The 7toX works fine for clips without audio. Good thing that the first program I exported accidentally has no audio or else it wont work at first try. I tried a regular program with audio and wont work at all except if you unsync the entire program. But nothing make any sense anyway. FCX has no export function.
Andrew Mehta
Re: Media100 XML
on Sep 30, 2012 at 7:14:38 am
XML is just plain text - you should be able to open it up in a text editor and see if there's anything obviously wrong with the syntax that's messing up the audio for you.
I've never touched Media100 or FCP7 XML exports... I've only ever used XML in a web context, to form playlists for a Windows Media Player Plugin. But it's a markup language, so should just be plain text tags.
