Media100 can't find Kona 3
COW Forums : Media 100
Gerry Condez
on Jun 6, 2012 at 5:20:47 am
Installed Snow then Installed version 2.1, No selection for Kona 3 within midi 100. I tried to upgrade to Lion and still no Kona can be seen within Media 100 A/V option. Why? Need advise.
Kona version downloaded was KONA 3 NDD Driver Version 10.3.1, Control Panel, and Notes
Michael Hanish
Re: Media100 can't find Kona 3
on Jun 6, 2012 at 10:16:12 am
Gerry,
You need to use an earlier version of the Kona driver as specified in the release notes, I think 9.05 or 9.06, until a Media100 update allows use of newer Kona drivers. MAke sure you uninstall the Kona software using the Uninstaller, restart, then install the correct version.
Hope this helps,
Gerry Condez
on Jun 6, 2012 at 12:37:20 pm
[Michael Hanish] "Gerry,
Hope this helps,
Thanks Mike, I saw the Kona back in Media 100. I used the 9.05. Took me a while to install everything fresh last night and I lost track of what version I installed. I probably installed all the latest version since they work with Final Cut X trial but now it does not show the A/V out for FCX, that does not matter anyway. Just checking if the kona card was installed right. Thanks again.
