Camera setup
COW Forums : Media 100
Gerry Condez
Camera setup
on Apr 13, 2012 at 11:34:23 am
Anyone here shoot a lot of footage from HD-slr? Any advice with common rig setup, cages or shoulder mounted rigs?
Sam Red
Re: Camera setup
on Feb 20, 2013 at 7:45:50 pm
I have and it just depends on what you are doing, I been using ikan for a while now and i like em a lot. The reality is that you will chose the right rig for you depending on a few factors including:
  • Accesories you are using
  • Lenght of shoot
  • Mobility
and overall look of your project...
A Glidecam, can work very effectively but it had a rather long learning curve and need to be balanced each time you pretty much set your camera and with each different lens configuration...
In there other hand a shoulder rig, positions the camera like traditional broadcast camera. It allows you to carry multiple accessories on your shoulder(follow focus,Sound recorder, monitor, light etc.)Shoulder rigs usually are good for semi-long periods of time when you need to be on the move.(I usually run with the ikan Ofly (http://ikancorp.com/productdetail.php?id=630) a the Zacutto Z-finder and the ikan follow focus.
Hand held Here is one i like from ikan too http://www.bhphotovideo.com/c/product/887739-REG/ikan_ele_ev2sf_Superfly_EV... is more for shorter runs when you want to pack light and still have stabilization and flexibility. You can still attach a follow focus a matte box and maybe a light and a small monitor like an ikan VL5...
Anyway i hope this helps.
