Page turn custom menu not working properly
COW Forums : Media 100
Larry Evey
on Mar 5, 2012 at 11:50:54 pm
Will someone check to see if your "Page Turn" effect custom menu is working. I cannot change the attributes with the sliders only by key entering a number in the field. I also cannot change the pull down menu of the page background element. I think this may be a bug in the 2.1 software?????
Larry Evey
West Coast MEDiA, Inc.
MEDIA100 Since 1993
616-874-8400
http://www.WestCoastMEDiA.com
http://www.OnCameraCoaching.com
http://www.linkedin.com/in/larryevey
Jaeson Koszarsky
Re: Page turn custom menu not working properly
on Mar 28, 2012 at 8:17:18 pm
I just tried it on my system and all seems in proper working order.
Media100 Suite2.1
MacPro 12core with 12GB RAM
OSX 10.7.2
I just added two different colour clips to the timeline and applied a page turn between them. I tried different settings and rendered ok in a 720x486 SD project with ProRes codec.
How is your project & system set up?
Jaeson
Larry Evey
on Mar 30, 2012 at 2:34:55 am
Thanks for checking on my issue with your system Jaeson. I see you have the 12core MacPro. I went with the 8core with 8gb of ram last May because the speed bump from 8 to 12 didn't seem to be that much. Do you notice increased speed with the 12core?? I'm still at OS 10.6.7 M100 2.1 as I have some old M100 projects that I still need to access.
Larry Evey
MEDIA100 Since 1993
616-874-8400
Jaeson Koszarsky
on Mar 30, 2012 at 3:54:43 pm
I stayed at 10.6.7 for the same reason, old m100 codec projects. But when 10.7.2 was green-lighted by Boris, I upgraded.
We moved from dual G5 systems to the 12-core MacPros, there a definite speed improvement. I can't compare 12-core to 8-core MacPros.
Jaeson
