FYI: HD Monitoring with DeckLink Pro-DVI!
COW Forums : Media 100
Rich Johnson
on Feb 28, 2012 at 6:40:17 pm
If anyone was looking into this low-cost HD monitor option I must say it works. At least for me.
I needed another HD Monitor and figured it was worth a try.
I wasn't expecting it to be this easy and look so good. I had to pull in the $3500 17"Panasonic HD monitor to check it out. Sat+Lum are a tad off... nut I'm not sure which monitor was off because I didn't bring in the scopes.
In any case: 1080x1920 HD monitoring on a 22' for under $600, esp. a second system is way worth it. (roughly $470 for DeckLink and $150 monitor) Although it said LCD or HDMI I had an LED around so I tried it and it worked. Only drawback is viewing SD. It will auto convert (faster than Panasonic but the quality is a bit shabby)
OnePlace Media, llc
Suite 2.1-LHe
OS10.6.8/7.2
Rich Johnson
Re: FYI: HD Monitoring CORRECTION!
on Feb 29, 2012 at 5:17:24 am
HDlink Pro DVI is the name of the product from Black Magic.
http://www.blackmagic-design.com/products/hdlink/
OnePlace Media, llc
Suite 2.1-LHe
OS10.6.8/7.2
