Color shift on export by ref
COW Forums : Media 100
Larry Evey
on Nov 3, 2011 at 3:02:57 pm
When we export the timeline by reference there is a color shift at the point where CG is inserted. Is this a known issue?
Larry Evey
West Coast MEDiA, Inc.
MEDIA100 Since 1993
616-874-8400
http://www.WestCoastMEDiA.com
http://www.OnCameraCoaching.com
http://www.linkedin.com/in/larryevey
Floh Peters
Re: Color shift on export by ref
on Nov 3, 2011 at 3:09:50 pm
This sounds like a mixed codec timeline. Most likely your source material is one format, your render codec is something else (e.g. Media 100 i and ProRes). Since they are in different colorspaces when being decoded to RGB by QuickTime, they do not match.
If you want to avoid that you either need to work in only one codec/codec family, or you need to do a QuickTime export to a codec of your choice.
Larry Evey
on Nov 3, 2011 at 3:46:16 pm
Thanks Floh, I thought I had everything set to ProRes. Is there a graphics setting for codec that I may have missed?
