Acquire Issue
COW Forums : Media 100
Joe Ciupik
Acquire Issue
on Oct 2, 2011 at 5:58:55 pm
I am trying to capture VHS into M100 using Kona LHE on OS 10.6.3. Signal indicators are green but no video or audio. Control Panel is set for 525i, component analog. Video input is set for SD Component. What am I missing?
Joe Ciupik
Re: Acquire Issue
on Oct 2, 2011 at 7:26:27 pm
Problem solved.
Michael Slowe
Re: Acquire Issue
on Oct 3, 2011 at 5:58:17 pm
Joe, tell us what the solution was, we can all benefit.
Michael Slowe
Joe Ciupik
Re: Acquire Issue
on Oct 3, 2011 at 6:11:14 pm
I had installed the KONA LHE card in the 3rd expansion slot. In reading a few posts on the web, the 2nd slot was "preferred". So I moved it and all worked well.
Please note that recently I had re-installed my 10.6.3 because, foolishly, I upgraded to 10.6.8 before I investigated if it was compatible with Media100. When I did the re-install I also installed the 9.0.5 AJA control panel. BEFORE the re-install, I was able to acquire without issue. It had been some time since I needed to acquire off tape. Yesterday I needed to do just that and the problem I listed appeared.
Whatever the actual reason or explanation, this worked for me. Hope this helps you if you are experiencing the same problem.
