SDI output shifted horizontally
COW Forums : Media 100
Jaeson Koszarsky
on Aug 23, 2011 at 3:51:38 pm
I'm using kona lhi & breakout box combo. I have the SDI out running from the BOB directly to the SDI in on my panasonic bt-lh1700wp monitor.
My problem is a huge horizontal shift. When viewing the test pattern in aja control, the white bar runs down the center of the screen. Media100 output is similarly shifted. Colour is ok.
Video looks fine in the Media100 monitors.
I tried running connecting the Panasonic SDI directly to the kona card SDI out and experienced the same horizontal shift.
I'm using aja 9.0.3 drivers, corresponding firmware update, osx 10.6.7, media100 suite2.0.2.
Suggestions?
Jaeson
Jaeson Koszarsky
Re: SDI output shifted horizontally
on Aug 23, 2011 at 8:27:18 pm
Not sure what was at fault but power cycling the monitor cleared up the problem.
Jaeson
