Force M100 to strip Alpha on import?
COW Forums : Media 100
Jaeson Koszarsky
on Jul 13, 2011 at 6:20:58 pm
Occasionally I import an MOV file that M100 says has an alpha channel, and M100 wants to change the codec to M100 HD. I don't need the alpha and would rather not switch to the HD codec. Is there a way to force Media100 to stick to the original codec and just ignore or strip the alpha channel? Thanks.
Jaeson
Floh Peters
Re: Force M100 to strip Alpha on import?
on Jul 14, 2011 at 9:58:15 am
No, currently not.
Dave McCarthy
on Jul 14, 2011 at 5:05:48 pm
You can use ProRes444 as an alternate codec that supports alpha.
Jaeson Koszarsky
on Jul 14, 2011 at 8:15:56 pm
Media100 doesn't give the option to select an alternative codec when importing. I can reprocess the file before the import with another app or inside the M100 after the import, it's just a few extra steps.
Dave McCarthy
on Jul 14, 2011 at 8:26:15 pm
True, but if you select ProRes444 before the import, that choice will be honored. It's only because you have a non-alpha codec selected that we force the change.
