844x codec greyed out
COW Forums : Media 100
John Twigt
on Jul 4, 2011 at 10:32:11 am
Hi ,
is it correct to assume that the 844x codec (Myuv) is not available in a Intel based M100 software? I have (on PPC) a version 1.1.3 which does have the choice of this codec but a (trial) V.2.0.1 (on an Imac) which doesn't give the option (greyed out) is there an extra 844x codec installer i should use or just forget about it. (i need to edit some stuff from the past which is only available as digitized 844x media, that's why)
thanks
John
John Twigt
Workstation BV, Amsterdam
The Netherlands
http://www.workstation.nl
Floh Peters
Re: 844x codec greyed out
on Jul 4, 2011 at 10:35:25 am
Hi John,
the 844/X codec never made the transition to Intel. So if you need to edit these files you probably have to do it on a PPC-based system.
John Twigt
on Jul 4, 2011 at 10:41:17 am
That's what i thought, thanks floh (swift as ever!)
John Twigt
The Netherlands
