Edit Suite problem
COW Forums : Media 100
Brian Uhler
Edit Suite problem
on May 18, 2011 at 9:00:59 pm
I am trying to digitize some footage from a beta deck. However every time I hit the Acquire button I get the following message "Could not switch to digitize panel because the Media 100 Suite System is locked up". I was working fine yesterday. I am on the newest version of media and my drivers are all up to date.
I even reinstalled Media thinking that might do something and same problem.
Anyone have any ideas????
Paul Crowe
Re: Edit Suite problem
on May 19, 2011 at 12:35:46 am
How is your drive space? Are you digitising to the same drive as yesterday? If not perhaps the new one is not fast enough?
Dunno, just ideas.
Cheers
Paul
Floh Peters
on May 19, 2011 at 10:10:55 am
You should delete your "Current Configuration" file in YourHomeFolder->Library->Preferences->Media 100 Suite Preferences. Most likely there is a setting that went wrong within this file. If you remember which configuration you used, you could try to delete the configuration file (located in the same folder) as well.
