Export problems
COW Forums : Media 100
Frank Cann
Export problems
on May 10, 2011 at 7:54:37 pm
Running M100 7.1
Trying to export a QT file from range. If I export a short clip - it works fine. If I do the same export with a longer range - upon completion it tells me that it's not a movie file to open.
I have tried different codecs with the same results.
Any suggestions?
Is this a M100 or a QT7 thing?
Floh Peters
Re: Export problems
on May 12, 2011 at 9:18:07 am
Are you really running Media 100 V7.1? Interesting. If this is the case, you could hit a 2GB filesize limit which was around in earlier OS versions. Or maybe your drive is formatted HFS and not HFS+, which also allows only 2GB. Try exporting short ranges, increase the length and look where it fails.
Frank Cann
Re: Export problems
on May 12, 2011 at 12:57:44 pm
Running 1.7 - sorry about that.
Dave McCarthy
Re: Export problems
on May 13, 2011 at 12:39:13 am
That's a relief!
What happens if you export the entire program?
Can you isolate the failure to a specific segment of the range? In other words, maybe there is a bad section of the program that would fail no matter how short the range.
Floh Peters
Re: Export problems
on May 13, 2011 at 12:17:37 pm
Another idea: you are not trying to export to an USB-Stick or a windows formatted drive? They still have a 2GB (or maybe 4GB) filesize limit on MacOS, as far as I know.
