Media 100 Suite v2.0.1 is now available
COW Forums : Media 100
Dave McCarthy
on May 2, 2011 at 1:47:07 pm
v2.0.1 is now on the downloads page
What’s new in Version 2.0.1?
Video Standards: New frame sizes for 3K video, in 16:9 and 2:1 frame aspect ratios, at frame rates from 23.98 to 59.94 frames per second.
Bin Settings: A bug which caused the “All” and “None” buttons in the View Settings window to be hidden has been corrected.
Edit Clip Panel: A bug which caused playback to stop in some situations when the user set a mark-in or mark-out has been corrected.
Motion Editor: The default setting when a clip’s frame aspect ratio differs from the program’s has been changed from black bars to crop. Motion Editor now maintains the state of the onscreen controls display separately for the “full source” and “composited result” preview modes. Holding the shift key while dragging the keyframe’s position or center of rotation will constrain the movement horizontally or vertically.
After Effects: A crash in Boris XML Transfer for Media 100 for Adobe After Effects CS5 in 64-bit mode has been corrected.
BorisRED: BorisRED 5.0.1 corrects a crash when editing titles.
Lukkee Chong
Re: Media 100 Suite v2.0.1 is now available
on May 6, 2011 at 8:02:06 pm
Hi Dave.
How compatible is this version with my system as described below?
PPC G5 Dual 2.7 GHz, 4 GB Ram. ATI Radeon 9600 graphics card, Atto ExpressPCI UL4D (dual), Ciprico U320RAID3/2k.
I am currently just barely running on Media100 Suite version 1.6 (PPC) with the HDx (Optibase) cards.
Regards.
Floh Peters
on May 8, 2011 at 11:59:15 am
[Lukkee Chong] "How compatible is this version with my system as described below?"
Suite 2 requires MacOSX 10.6, since some of the used technology for the scaling and the Red support is only found in OSX 10.6 and higher. Since 10.6 is only supported on Intel Macs, I guess you are out of luck with a PPC-based system.
Lukkee Chong
on May 12, 2011 at 3:19:44 am
Thanks Flo. I guess it's upgrade time!
