m100 and AE xml error
COW Forums : Media 100
Paul Crowe
on Apr 11, 2011 at 10:31:29 pm
Hi there,
this may be an AE question but as the problem has only started showing itself since I set up the M100 - AE xml interface I thought I'd run it by you guys. This is the first time I've done this and was really excited to see the timeline turn up in AE with separate tracks etc. Awesome.
So I work away grading etc on the short 3min project in AE. Looking great, then try to render out and about a third into the render I get a long system error code that starts AE encountered an error {/Chincillada/pro/ext/adobe...blah, blah, blah it goes on for ages (i've written it down if it helps any one) followed by another AE warning which simply says, AE cant continue: An input contract violation has occurred.
I'm pretty sure its an issue with the xml transfer because when I export the project as a continuous video QT out of the same M100 timeline and import it into the same AE project it renders out just fine.
Any one had similar issues? Help or comments would be greatly appreciated.
I'm running OSX 10.6.7, M100 suite 1.7 and AE CS4.
© 2018 All Rights Reserved
