import from cd
COW Forums : Media 100
Murray Ferguson
import from cd
on Mar 23, 2011 at 1:08:04 am
Having trouble importing a music track from CD on M100 1.7.1. It eventually works but it takes about a minute then the import box hangs for a further minute before disappearing. Anyone else experiencing this, or know why?
Paul Crowe
Re: import from cd
on Mar 23, 2011 at 1:35:57 am
I seem to remember having this problem at some point. But not for some time.
From memory in this case, I tracked it back to disc damage...
Have you tested it from a different cd?
Or perhaps copy the track to your drive first to see if its bringing it in directly
off the disc that your set up is having the problems with.
Cheers
Paul
Murray Ferguson
Re: import from cd
on Mar 23, 2011 at 1:52:14 am
Thanks Paul, I did try several CD's but hadn't tried copying to the desktop.
This way it imports in a flash, so thanks. Still not sure why it won't work directly though.
