Media 100 export to After Effects
COW Forums : Media 100
jeremy Rowell
on Jan 27, 2011 at 12:50:15 am
Just upgraded to 1.7... now when I export a project to After Effects (CS4 9.0.3.8) I get an error in AE that "AEGP plugin Boris xml transfer for media 100: cannot import this file with the media 100 xml importer"
Anyone have any ideas?
Can anyone running this configuration test to see if they can export a project to AE?
Jeremy
Floh Peters
Re: Media 100 export to After Effects
on Jan 27, 2011 at 1:16:56 am
Seems to work for me. One thing you could try is to downgrade to the older version of the AE importer if you have a backup of it. It should read exports from Suite V1.7 still fine.
Dave McCarthy
on Jan 27, 2011 at 2:52:49 pm
The most common cause of that error is that you did an Export to XML from Media 100 instead of Export to After Effects. (Or you tried importing the wrong file in After Effects.) I think you emailed a file to support and it was the correct type, but I don't know if we tried to reproduce the problem yet.
