Export settings
COW Forums : Media 100
Sue Daly
Export settings
on Dec 21, 2010 at 3:09:01 pm
Hello,
Can any one tell me where I'm going wrong with exporting from my Meida 100 edl to create a 16x9 Quick Time Movie? (I'm using Media 100 Suite) My work is all in 16 x 9 but whenever I export anything it creates a 4x3 movie. I can convert it to 16x9 in Quick Time Pro but when I send it to a conversion web site, I use BlipTV so that I can use it on my own web site, it comes out as 4x3 again. It's driving me nuts!
Sue
Sue Daly
Eric Pelletier
Re: Export settings
on Dec 21, 2010 at 3:36:11 pm
is this 4x3 movie looking squeezed horizontally? (Or streched vertically?)
If so, it's normal since you're outputting an anamorphic 16x9 movie.
If you want it to look "normal" on a computer screen, output to 16x9 with these dimensions :
PAL 1024x576
NTSC 854x480
NTSC 864x486
Sue Daly
Re: Export settings
on Jan 11, 2011 at 2:17:15 pm
Many thanks - with apologies to taking three weeks to reply!
Sue Daly
Sue Daly
Re: Export settings
on Jan 12, 2011 at 7:42:07 pm
Me again, still struggling with export setting from Media 100 Suite. I'm now trying to create a DVD (PAL) that will play on a computer and in a standard, hooked up to a telly DVD player in 16x9. My project is filmed and edited in 16x9. I'm using iDVD to make the DVD. So far I can make a 16x9 DVD that is horribly cropped way beyond the safe area setting in iDVD or I can make a DVD that ends up being 4x3. Where am I going wrong?
Sue Daly
Floh Peters
Re: Export settings
on Jan 13, 2011 at 3:01:22 pm
Hi Sue,
what version of iDVD are you using? I think I remember that some iDVD versions only supported 4:3 media. Is there a 16:9 setting in your iDVD version?
Sue Daly
Re: Export settings
on Jan 13, 2011 at 3:54:31 pm
Hi Floh,
I'm using iDVD6 and it does offer the option of 4x3 or 16x9.
All the best,
Sue
Sue Daly
Floh Peters
Re: Export settings
on Jan 14, 2011 at 3:54:09 pm
Hi Sue,
locate the exported QuickTime in the Finder. Open it in QuickTime Player (Pro). Under Movie Properties (Command-J) select the Video Track, and set the "Scaled Size" (under the Visual Properties tab) to 1024*576 for PAL or to 864*486 (if my math is correct) for NTSC. Save the file and open the file in iDVD again.
One additional note if you are working in NTSC: I am not sure if iDVD does the 486->480 (for MPEG2) conversion correctly. If you are seeing interlacing artifacts, you could export a DV Stream from Media 100 instead a by-reference or self contained movie. This should be in 720*480 already, which is perfect for DVDs. Then set the size to 854*480 in QuickTime Player and continue to iDVD.
