XDCAM Transfer crashes Suite 1.6 on import
COW Forums : Media 100
jay Ryscki
on Dec 13, 2010 at 11:39:20 pm
I just upgraded to 1.6.3 and things have gone in the tank. Prep my clips using ShotPut3, Rename and organize in XDCAM Transfer, have M100 open and set with media destination folders, Codec is set for prorez 422 HQ and it will import until I hit a clip that's over a minute in length. Over and over. Transfer continues on without M100. The clip that does make it into the bin works fine. I can batch 50 clips if they are less than a minute each. The error is a -19524. This was happening last summer when I started working with 1.6
Floh Peters
Re: XDCAM Transfer crashes Suite 1.6 on import
on Dec 14, 2010 at 11:29:07 am
Hmm, that´s strange. Do you have the latest XDCam Transfer app installed (V2.12)? If not, try upgrading to the latest version. We do batch import longer clips all the time without issues. I guess if you still get crashes with the latest version you should contact Media 100 support with your error log details. Usually they are pretty good about fixing these issues if it is a bug in their software.
