s/pdif
COW Forums : Media 100
Gerry Condez
s/pdif
on Nov 22, 2010 at 11:25:33 pm
Can I connect a S/PDIF audio directly to media100i or the meda100 HD Kona3 box through the AES/EBU or the RCA connectors?
Thank You,
Floh Peters
Re: s/pdif
on Nov 23, 2010 at 2:17:32 pm
You should be able to connect S/Pdif to the AES/EBU connectors, since S/PDif is a subset of the AES signal. Usually the AES/EBU XLR input should accept the incoming signal.
