audio clicks
COW Forums : Media 100
Paul Crowe
audio clicks
on Nov 7, 2010 at 11:23:59 pm
Hi folks.
Running M100 SUite 1.5.1 on 10.5.8 (I know, I know. I need to upgrade OS - going to SL soon!)
Anyway, I'm experiencing some really very annoying audio clicks at the end of audio clips. Not all of them just some of them.
For the most part it gets pretty easily sorted out in the mix (ie cross fades etc) but I still don't believe this should be happening, I'm also getting what I can describe as terrible crackling sound when I set the audio scrubbing to either scan or scrub and drag the play head over the time line,the cracking is so dominate that I cant actually hear what I'm trying to scan or scrub - arrgh!!.
Any help with how to fix this or some explanation as to why it's happening would be greatly appreciated.
Cheers
Paul
Floh Peters
Re: audio clicks
on Nov 8, 2010 at 4:06:41 pm
What audio output hardware are you using? I haven´t heard about this problem before… Are you maybe using a sample rate other than 48kHz?
