Export function crashes: Producer 13.0.4
COW Forums : Media 100
Robert Vandeweghe
on Sep 30, 2010 at 5:09:58 pm
Last night I when to export a short program-line edit and after clicking "Export" from the "File" menu, I got the Mac spinning beach-ball for 30 seconds and then M-100 quit. This happen a few more times after relaunching M-100. I then tried going back to a recent project that I was able to export just the other day and tried to re-export that project and the same thing happen, the M-100 application quit.
I ran "Verify & Repair Disk" - zap the P-RAM and rebooted the Mac. But the problem is still there. I also removed the Media 100 preference folder and relaunch M-100, but still I can not Export.
Any ideas?
Robert
Floh Peters
Re: Export function crashes: Producer 13.0.4
on Sep 30, 2010 at 6:37:03 pm
Do you have installed a new quicktime codec? Anything unusual in your Library->QuickTime folder?
Robert Vandeweghe
on Sep 30, 2010 at 6:57:10 pm
Floh,
Thanks for your response. I have not up dated my QuickTime - I am using Qt v7.6.0.
I checked out the QT folder in the apps library. The last time that I exported out of M-100 was on 9/14 - Interestingly there are two files in the QT folder from that same date:
AC3MoiveImport.Component
and
SMIQuickTimeExportComponent.component.
I don't know if that is unusual or not.
Robert
Floh Peters
on Sep 30, 2010 at 7:13:00 pm
Drag them to the desktop and see what happens. If the app still crashes you can move them back to the Library->QuickTime folder anyway.
Robert Vandeweghe
on Sep 30, 2010 at 7:19:59 pm
Floh,
I dragged the two files from the QT Library folder and then I tried to export my video edit from M-100 time-line and this time it worked!
Thank you so much! If I can ever be of service let me know!
Best regards,
Robert
Gregg Michaels
on Sep 30, 2010 at 7:35:47 pm
I can confirm that SMIQuickTimeExportComponent.component causes many issues with the export process in Media100 of old and new. It gets installed with Sorenson Squeeze. I have passed this info along to the support guys, but I don't know of a resolution other than to remove it from the QT folder.
GM
Robert Vandeweghe
on Sep 30, 2010 at 7:44:34 pm
Floh,
As I told you, I had exported a video out of M-100 on 9/14. After that I wanted to make a Flash version for the web. I was not happy with the quality of the QT version "flash" so I down-load a trial version of Sorenson Squeeze. I was happy with the quality of Sorenson Squeeze flash and hope the teck-guys can work out the bugs!
Once again, thanks for your help!
Have a great day,
Robert
