16x9 goes 4x3 on export
COW Forums : Media 100
noah wight
on Jul 29, 2010 at 6:32:36 pm
So not sure what I'm missing here but I'm exporting a 16x9 program and it's coming out as a 4x3 clip. I've tried every possible combination of settings but can't seem to get it out at 16x9. Anyone know what I'm missing? Running into a time issue on this. Thanks.
Floh Peters
Re: 16x9 goes 4x3 on export
on Jul 29, 2010 at 7:38:45 pm
Are you exporting an SD clip? Then this is perfectly normal. Simply open it in Quicktime player, and set it's dimensions to 1024*576 for PAL or 864*486 for NTSC under the Video track settings (Command-J), then save it again. During export the anamorphic setting does not get written to the Quicktime file. The same happens for example when rendering out movies from AfterEffects.
noah wight
on Jul 29, 2010 at 8:13:51 pm
Wow. Thanks. That was a pretty ridiculous process. Must have missed this in the manual.
