Transitions disappearing when moving edits
COW Forums : Media 100
Robin Hamilton
on Jul 27, 2010 at 9:38:33 pm
We recently just did a multi-chapter DVD. The whole edit was on one timeline with black in between each section, and each section exported for transcoding for DVD. After this was done there was a request made to compress the entire show for the web. There was a little too much black between each section so I tightened up the gaps by using "select from here" to move large edited pieces closer together. After exporting the show and compressing it, I noticed that there were a few transitions that disappeared. Also, there were transitions added to clips after a transition occurred on some tails left on the video. (The transition would end, then cut back to the previous shot for a few frames, then back to the proper shot.) Here is a link to a screen capture of what I'm talking about. I thought I may have inadvertently somehow added the cut back to the clip, but I am able to randomly reproduce the problem by selecting all clips and moving them along the timeline.
I remember losing transitions or transitions becoming unrendered on our old v7 M100 when selecting sections and moving them along the timeline. I was hoping that would been fixed. Has anyone else experienced this? Is there a workaround?
Robin Hamilton
Re: Transitions disappearing when moving edits
on Jul 27, 2010 at 9:55:11 pm
I forgot to mention we are running M100 Suite v1.5.
Also I am aware that cleaning all clip tails will help solve my second problem, but it won't stop the transitions from disappearing. For some reason I am a little afraid of the clean program button for fear of strange things happening.
-RH
-Robin Hamilton
Motion Graphics Designer
Visual Productions
Floh Peters
on Jul 28, 2010 at 9:14:57 am
The "Clean Program" always has been 100% reliable to me, and I use it very very often. So personally I think there is no reason not to use it.
The Transition disappearing problem happened to me also some times; usually this is because there is a problem somewhere in the timeline, like a "bad cut" or transition. Problem is that I still haven´t found a way to reproduce this problem, in other words I don´t have an idea how these bad cuts find their way into a timeline. Once it is there, the app gets confused about its transitions/cut points, and therefore sometimes accidentally removes or adds transitions or cuts when moving clips. Personally this happens very rarely to us; problem is that as long as there is no way to reproduce the steps leading to such a bad cut, finding the reason for it and fixing it is pretty hard.
There were some additional situations where this could happen on V7, and some have been fixed; but obviously there is still a situation when this can happen.
Floh
olof ekbergh
on Jul 28, 2010 at 12:53:17 pm
I have a long timeline more than an hour, that I have to keep modifying for a client. It has a few of those "bad transitions" every time I move the clips they get corrupted and I fix them. But the next time it happens again.
I can put this program up on an ftp site if someone wants to check it, to find out why it happens.
Olof Ekbergh
Floh Peters
on Jul 28, 2010 at 12:55:55 pm
Yeah, problem is that the question is not why this happens, but how the bad transitions got into the timeline the first place. That is the part I still was not able to figure out.
olof ekbergh
on Jul 28, 2010 at 2:39:14 pm
Do you think it may have something to do with a clip that has been moved from a super track down to the V track and then had a transition applied.
I have sometimes had problems with clips that have been moved between V-tracks and supers.
Olof Ekbergh
