Vs 12.1.3 problems playing back
COW Forums : Media 100
Joshua Young
on Jul 27, 2010 at 6:15:20 pm
Hello
Recently my Media 100 System is having more and more problems playing back video. I thought it was a memory problem but upgraded to 6 gigs and im still getting "real time errors occurred where ther are no items to render." I have a 2x2.66 ghz dual core intel processor. I am using the DVCPro HD codec with has a data rate of 100mbps. Any thoughts? Also what is the highest version of quicktime I can run with this version of media 100. OSX?
Yoshi
Matthew Mullen
Re: Vs 12.1.3 problems playing back
on Jul 28, 2010 at 2:55:28 am
Are you using any I/O hardware?
Try setting the video output to none, does this resolve the error?
Joshua Young
on Jul 29, 2010 at 6:12:07 pm
Hi Matt,
I am using a HDe interface. I have over 50 gigs available on each drive. I have run disk warrior on all dives. It just kind of started happening. A little worried.
Joshua
Yoshi
“If you ever see me being beaten up by the cops, put down the video camera and come help me, alright?”- Bobcat
Matthew Mullen
on Jul 30, 2010 at 1:35:32 pm
Did you try toggling your video output setting to none in media 100 as I suggested?
Joshua Young
on Jul 30, 2010 at 3:33:15 pm
Matt,
I set ouput to none and still there are problems. Any other suggestions?
Yoshi
Matthew Mullen
on Jul 30, 2010 at 4:51:45 pm
Are you sure your media is DVCPro? Check your bin in list view.
Floh Peters
on Jul 28, 2010 at 9:16:51 am
Besides a hardware conflict or board placement problem (which Matt is referring to) it also could be that your media drive is very full or fragmented.. This usually also can result in lower drive speeds and therefore to realtime playback problems. Have you checked your media drive with Apple DiskUtilty lately?
