Media 100 Suite V1.6 released
COW Forums : Media 100
Floh Peters
on Jun 14, 2010 at 9:49:33 am
As the title says, version 1.6 of Media 100 Suite has been posted to the Media100.com download area. New features are native support for AVC Intra formats as well as faster Boris RED rendering and an updated AfterEffects exchange plugin for AE CS5.
Peter DeArmond
Re: Media 100 Suite V1.6 released
on Jun 14, 2010 at 3:52:35 pm
This is great news, Floh, thanks!
Question: Does 1.6 also support AVCHD (the lower bit rate) as well as AVC-Intra?
Floh Peters
on Jun 14, 2010 at 4:29:47 pm
[Peter DeArmond] "Question: Does 1.6 also support AVCHD (the lower bit rate) as well as AVC-Intra? "
AVCHD is supported since Version 1.5 via ClipWrap; although only as a slow import (conversion into a supported codec). The difference is that AVCHD uses an interframe compression, creating groups of pictures sharing the same compression data, while AVC Intra is a intraframe compression, where each frame contains the whole image. Supporting interframe compressed material like HDV and AVCHD natively seems to be difficult inside the Media 100 software environment.
René van Broekhoven
IMPORTING PANASONIC 3700 (AVC INTRA MFX) FILES INTO MEDIA 100 SUITE
on Aug 20, 2012 at 5:22:06 pm
What's the best codec to use ?
I have just bought a Panasonic Varicam HD camera; superb picture quality, etc.
This camera creates MFX files on a P2 memory disk.
My video editing system is Media 100 Suite, version 1.7 (intel) installed on a MacPro 5.1 (OS-X 10.6.8)
Importing the camera files into Media 100 does not work via the Panasonic P2 option, so I have installed third party software (Calibrated Q) to do this, resulting in an AVC Intra option which seems to work fine.
My question is : what is the best option to import files
Media 100 HD, 8- or 10-bits uncompressed ? This results in fil;es 10 times larger than the MFX files.
Or should I go for one of the other codecs like ProRes ?
If there's anyone who's got some experience with this and is willing to share this with me, please response. Thanks in advance.
René van Broekhoven
RBS Groep, Rotterdam, The Netherlands
http://www.rbs-group.nl
mail@rbs-group.nl
Floh Peters
Re: IMPORTING PANASONIC 3700 (AVC INTRA MFX) FILES INTO MEDIA 100 SUITE
on Aug 21, 2012 at 10:34:43 am
[René van Broekhoven] "Or should I go for one of the other codecs like ProRes ?"
We use ProRes for nearly everything. Definitely give it a try.
