Memory Allocation Failure - Can't Render
COW Forums : Media 100
Marcus Warren
on Jun 7, 2010 at 5:16:12 pm
I am getting a Memory Allocation Failure problem with Producer v13 that will not allow me to render anything. I also get the Unrecoverable Error box with parameters. I'll send that information off to the Media 100 techs, but thought that I would try here first. I don't have the error code handy.
At this point I can edit, I just can't render. Trying to render gives me the Can't Render All because of a Memory Allocation Failure flag and the Unrecoverable Error box. After I closed the box and flag M100 shuts down. I can reopen and edit, but trying to Render or Render All gives me the Memory Allocation Failure flag and the Unrecoverable Error info box.
I noticed that on an discussion thread on this forum from earlier this year there was never a resolution to that individual's Memory Allocation Failure problem.
I have a MacBook Pro with 4GB RAM and Leopard 10.5.6.
Thanks for your help
Matthew Mullen
Re: Memory Allocation Failure - Can't Render
on Jun 7, 2010 at 5:23:03 pm
Marcus,
I would start by trashing preferences and rebooting the machine then trying again.
To delete prefs: Navigate to the Mac HD> Users> Current User> Library> Preferences.
In here locate and delete the Media 100 and/or media 100 Suite preferences
folders.
Also there should be some files that begin Com.Media100. Delete all of
these except the com.media100suite.Registration.plist file.
Marcus Warren
on Jun 7, 2010 at 6:35:32 pm
Thanks. I attempted to do that yesterday but I did not go into the Users>Current User file. I went through another folder to Preferences and did not see any com.Media100 files. Thanks for giving me the correct pathway. I'll let you know if it works.
Marcus Warren
on Jun 8, 2010 at 6:22:32 pm
Thank you, Matthew. Deleting the Preferences files did the trick it seems.
Matthew Mullen
on Jun 8, 2010 at 6:27:34 pm
Glad to hear, let me know if it comes back up or if you need anything else.
