audio error on export
COW Forums : Media 100
Jerome Robbins
on Mar 17, 2010 at 4:14:35 pm
Mac OS 10.3.9 media 100 8.2.2 l/xr
I digitized a cassette tape of voice audio into the NLE adjusted on the timeline. I have tried exporting as an AIFF and QT movie but keep getting an error message a few minutes into the export.
Any ideas as to why the audio won't export? What can I try?
Thanks for any help!
Matthew Mullen
Re: audio error on export
on Mar 17, 2010 at 4:18:54 pm
What is the error message?
Jerome Robbins
on Mar 17, 2010 at 4:43:46 pm
a window comes up with the word ERROR in the title and the window is empty and grayed out. The system locks up and I have to force quit and re-start.
jerome
Matthew Mullen
on Mar 17, 2010 at 4:50:52 pm
try exporting something else. Does it happen with all exports or just this program?
Can you try running the hardware test and report the results.
Jerome Robbins
on Mar 18, 2010 at 6:45:12 pm
I tried exporting a short video + audio clip as a reference movie. I got the big error window:
error -19003 Paramater 1 $6151557 the rest parameters were $0
socket 7 line 367 hardware rev 802
So I rebooted and exported as a self contained movie: It exported fine.
Then I tried an audio only track again as AIFF and got the Error window with nothing in it but it was locked up.
The media 100 8.2.1 for Mac OS X disc lists on the cover Application Install and hardware Diagnostics.
But, when I insert the disc it has: Media 100i installer, Media 100 manuals, Wipe designer Examples, Adobe after Effects Plug in, Bars and Tones, and 844X 2.0.5 InstantMedia
there is no Hardware Diagnostics.
Do you know what I am suppossed to do to test the hardware?
jerome
Matthew Mullen
on Mar 18, 2010 at 7:35:11 pm
There should be a hardware test in the Applications> Media 100 folder.
What version of Quicktime are you using?
Jerome Robbins
on Mar 18, 2010 at 10:40:12 pm
Thank you very much. I found the hardware test and ran it. Results everything passed.
The QT viersion is 7.2.0
I have some audio voice tapes to put on CD. I was hoping to use Media100 as I am most familiar with it and have done it before. But maybe I will have to use Garge Band and run the audion tape signal through an iMic.
I still would like to solve this issue though. Thanks for the help.
jerome
