M100 support pro res proxy
COW Forums : Media 100
todd mcmullen
on Feb 3, 2010 at 9:43:45 pm
Trying to understand if M100 Suite supports pro res proxy?
I see pro res but looking for more of a draft mode as well. any ideas?
thanks
Todd McMullen
Flip Flop Films
Austin
http://www.toddmcmullen.com
Floh Peters
Re: M100 support pro res proxy
on Feb 3, 2010 at 9:49:04 pm
The current release does support playback of ProRes Proxy files. If you want to learn more about the next update you can join the webinar scheduled for tomorrow…
todd mcmullen
on Feb 3, 2010 at 10:12:13 pm
Thanks Flo,
So the current version supports playback.
But, I am assuming I cannot capture Pro Res Proxy in M100?
What time is the webinar?
Todd McMullen
Flip Flop Films
Austin
Floh Peters
on Feb 3, 2010 at 10:17:49 pm
The info about the webinar is at http://www.media100.com. And yes, ProRes Proxy playback means being able to play back (and not to acquire) clips in ProRes proxy codec.
Jim Wiseman
on Feb 5, 2010 at 3:22:16 am
Would the latest AppleProResCodec.component for Final Cut 7 have to be installed in Library/Quicktime for playback to work in Media 100 Suite? I assume it wouldn't work if it were not there. Would that codec work for playback with M100 Suite 1.1.3 in Leopard 10.5.8? Or would it be limited to the older codec that only includes 422 and 422HQ?
Jim Wiseman
Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Final Cut Studio 2 and 3, Media 100 Suite 1.1.2, AJA ioHD, AJA Kona LHi Avid MC, Macbook Pro Core2Duo, G5 Quadcore PCIe, Media 100i/XR
Floh Peters
on Feb 5, 2010 at 6:58:44 am
[Jim Wiseman] "Would the latest AppleProResCodec.component for Final Cut 7 have to be installed in Library/Quicktime for playback to work in Media 100 Suite?"
No, it does not. The playback components for ProRes are included in the standard QuickTime install; I can´t remember which version of QuickTime started this, but I think it was 7.6 or 7.5. You can look at the Media 100 info screen (in the "About Media 100" window) to see which codecs and hardware options are available. Most likely some of the ProRes codecs are shown as "Playback Only"
