FCP XML to Media 100 1.1.1
COW Forums : Media 100
Ben Masterson
on Dec 10, 2009 at 9:18:31 pm
I was wondering if there was something special you had to do to get an XML of a timeline from Final Cut Pro v 7.0 to Media 100 Suite 1.1.1. I think I have tried every XML version Final Cut does...but Media 100 says it is not a recognizable XML file. With the error invalid xmlChar value 8 in the Log window. This timeline was originally xported as an XML from Media100 to Final Cut.
Is there anything special I have to do? I haven't found anything online yet
-Ben
Matthew Mullen
Re: FCP XML to Media 100 1.1.1
on Dec 10, 2009 at 9:32:36 pm
Ben,
How are you creating the XML in FCP?
It sounds like there might be something in the XML that M100 doesn't understand.
Can you send the XML to support@media100.com attn:Matt. I will try to take a look and see.
As a test create a new project in Final cut, just toss in some color bars, export an XML and see if that works just to make sure.
-Matt
Ben Masterson
on Dec 10, 2009 at 10:22:57 pm
Ok I tried it with another program and it worked. Upon further inspection, FCP is seeing my timeline media as "offline" even though it is playing fine. I had originally exported this timeline from Media 100 as xml and imported it into FCP, I guess that is where the screw up happened.
Matthew Mullen
on Dec 11, 2009 at 4:48:12 pm
If you want send me the original XML and the most recent XML and I can take a look at it.
