XDCAM - 1080p/1080i
COW Forums : Media 100
Jack Shepard
XDCAM - 1080p/1080i
on Oct 8, 2009 at 5:48:56 pm
Bit confused...
Editing something on XDCAM which was shot at 1080p29.97fps. I'm mobile at the moment so I am cutting from a laptop and am using the DVCPROHD codec due my speed constraints.
I imported it into Media 100 as DVCPROHD and have been editing it in a 1080p29.97fps timeline.
When I export it to a by-reference clip and select "get info" on it. It tells me that the codec is DVCPROHD but 1080i60. Or if I open an XML into Media 100 the sequence settings also tell me it is 1080i.
I'm confused. Why is it suddenly 1080i?
Thanks.
Wickham Strub
Re: XDCAM - 1080p/1080i
on Oct 8, 2009 at 7:32:09 pm
That's just the name of the codec. I have no idea WHY they named it that way, but that's what you're seeing.
To reassure yourself, try the following in Media 100:
- Load a clip into the Edit Suite.
- Hold down the Command (apple) key while tapping on the left and right arrow keys. This will step through fields on interlaced media.
- If it's interlaced, you will see that it takes two taps of the arrow to move the timecode one frame.
- If it's progressive, one tap of the arrow will advance the timecode whether you are holding the Command key or not.
Jack Shepard
on Oct 8, 2009 at 11:13:05 pm
It is progressive. Wasn't making any sense to me that it wouldn't.
Thanks Wick, what a strange way to name that codec!
Michael Slowe
on Oct 9, 2009 at 3:52:40 pm
Wick, what happens if we hold our left ear with our right hand and then tap the arrow keys,maybe a pretty girl in a bikini will appear on our screens?
Michael Slowe
Wickham Strub
on Oct 10, 2009 at 2:50:53 pm
Micheal,
Lest you think I have no sense of humor, I have composed several snappy comebacks in the last 24 hours. Alas, none have been appropriate in the presence of mixed company ;-)
~Wick
