Quick SD PAL question.
COW Forums : Media 100
Andrew Mehta
on Aug 30, 2009 at 5:59:23 pm
Haven't spent much time with M100 Suite v1 yet [need to install 1.01 too at some point], but when I did fire it up and have a quick gander, I couldn't see an option for 720x576 25fps [SD PAL essentially]. I could only see 625i 25 or 625psf 25...am I missing a codec, or is that what you call PAL nowadays?
Sorry if I sound a bit ignorant of basics, I haven't done any video stuff for a few years now.
Wickham Strub
Re: Quick SD PAL question.
on Aug 30, 2009 at 6:09:08 pm
We changed the way things are labelled a little while ago to better match the way some of the other apps and hardware we now work with name things.
If you're doing plain-vanilla PAL SD, then you want 625i.
