Media 100 Suite v1.0.1 adds suport for AJA v6.5 Drivers
COW Forums : Media 100
Wickham Strub
on Aug 23, 2009 at 1:50:37 pm
Here's how my announcement post from Friday SHOULD have read.
- Requires AJA v6.5 drivers* to run with AJA Kona line of cards, including the new LHi
- Fixed an issue where transitions to and from a MultiClip where removed when choosing "Make Separate Clips from MultiClip"
- Fixed an issue where HDMI input was not correctly indicated in the Input Channel Mapping window when using the AJA LHi
- Fixed an issue where some files would import with their audio tracks drastically out of sync.
- Fixed an issue where transitions between 1080p and 1080i clips would not render correctly
- VoiceOver tool now shows correct CTI position when a record is aborted
- HDx-based systems can now acquire 1080psf as 1080p
- Improved 1080p playback to 1080i output with HDx cards
- Improved support for Matrox MXO2 line of I/O devices
* For those using FCP 6.x, there is some confusion about whether or not they can use the new AJA drivers. We have been told by engineers at AJA that FCP 6.x WILL work on the v6.5 drivers from AJA.
olof ekbergh
Re: Media 100 Suite v1.0.1 adds suport for AJA v6.5 Drivers
on Aug 23, 2009 at 4:16:30 pm
Thanks Wick.
That is great I will now update my HDe system as well. The MX02 is running great with FCP7.
Now we can take advantage of the Color 1.5 roundtrip that Floh's great tutorial outlined on Kona systems as well.
Olof Ekbergh
Robert Stone
on Aug 24, 2009 at 6:37:16 pm
Mahalo!
Robert Stone
http://www.TaylorCampFilm.com
http://www.youtube.com/MauiFilms
