Audio out
COW Forums : Media 100
Frank Cann
Audio out
on Aug 7, 2009 at 6:30:30 pm
I know there has to be a better way...
With my Media 100 audio set at 44100 Hz - its way too strong of a signal for my analog DVD-R machine. To overcome this I have been dropping the bus to about -17 db.
Is there something I should be doing different?
Floh Peters
Re: Audio out
on Aug 7, 2009 at 9:33:40 pm
Which system? How is your analog audio set up? Which connections? And why are you using 44.1???
Frank Cann
Re: Audio out
on Aug 10, 2009 at 1:16:01 pm
Sorry about that -
System M100 Suite V 1 (Intell)
Source In - Analog - using XLR cables
Convert to 44100 Hz
Output Kona HHe
Rate 48000 HZ
Sync audio to analog
Floh Peters
Re: Audio out
on Aug 10, 2009 at 2:58:51 pm
So I guess you are using a Kona LHe? Look in the Audio out prefefences for the analog audio level selection and set it to a value that works with your DVD recorder…
