XML to AE
COW Forums : Media 100
Frank Cann
XML to AE
on Jun 30, 2009 at 9:11:34 pm
(with no directions from M100) - I have downloaded the Adobe After Effects Project Importer and dropped it into the AE plugins/format folder.
Restarted AE - created a new project & attempted to open an exported XML file - but with no luck.
Any thoughts?
(M100 V13.02 - AE CS4)
Floh Peters
Re: XML to AE
on Jul 1, 2009 at 9:22:44 am
Adobe once again has changed the AE import approach for CS4. The plugin you have downloaded should work in CS3, but right now not in CS4. You need an updated plugin for CS4, which I would guess could arrive around the time of the next Media 100 releaseā€¦
A workaround right now is to import the XML into AE CS3, save the project there and then open it in CS4. Not perfect, but works flawlessly.
Frank Cann
Re: XML to AE
on Jul 1, 2009 at 12:57:52 pm
Thanks Flo -
