M100 bin to FCP
COW Forums : Media 100
ralph conradt
M100 bin to FCP
on Jun 19, 2009 at 6:29:12 pm
The editor I like works only in FCP. He would like to re-capture all the media in the project. I know the program XML file can be brought to FCP but M100 support tells me FCP does not recognize M100 bin info.
Is there a workaround?
Thanks a lot
Wickham Strub
Re: M100 bin to FCP
on Jun 19, 2009 at 7:03:25 pm
Hi Ralph,
I've done this before myself, and I just double-checked it before writing this reply.
1 - Drag and drop all your clips from a M100 Bin into a M100 Program.
2 - Export that Program to XML.
3 - Bring the XML into FCP.
4 - Open the resulting Sequence in FCP.
5 - Drag and drop all the clips from the FCP Sequence to a FCP Bin.
As workarounds go, it's extremely painless.
ralph conradt
Re: M100 bin to FCP
on Jun 19, 2009 at 7:10:46 pm
thanks. I was just about to do something like that cause I need to figure out the disk space. FCP tells you the time in each bin. Can't find such a command in M100 user gyuuide so was going to drag all the bins to a timeline.
Jim Wilcox
Re: M100 bin to FCP
on Jun 19, 2009 at 8:38:19 pm
you can run a script that comes with M100 that is called something like "sum of bin durations" which will give you the combined length of all the clips in any bin. Is that what you are trying to do?
ralph conradt
Re: M100 bin to FCP
on Jun 19, 2009 at 8:36:01 pm
Yes, sum of bin duration is exactly what I want however I have never done any "script" work.
I just dragged the 20 bins to a timeline and added them all up manually. Took me a while but probably a lot less time than trying to learn teh script.
Thanks for the thought tho
Jim Wilcox
Re: M100 bin to FCP
on Jun 19, 2009 at 10:51:45 pm
Ralph,
That's the beauty of this script...you don't have to write it. If you have your bin selected and just go to the script icon pulldown menu and select that script a dialog box will pop up and tell you the duration of clips in that bin.
