Timecode export
COW Forums : Media 100
Doug Calhoun
Timecode export
on Jun 18, 2009 at 7:13:19 pm
I've searched and found a thread from 3/08 stating it would be coming in the next couple releases but still no...
Does anyone have a workaround for exporting timecode burns out of M100 for DVD approval? Having to master, digitize, encode, burn and ship....
Any help appreciated,
Doug
Floh Peters
Re: Timecode export
on Jun 18, 2009 at 9:05:34 pm
Actually the next release will allow exports with TC superimposed in the image. Currently you e.g. can add a Tc overlay in Compressor, or create a TC overlay clip for use with Media100 exports in AE or Red (render it out with alpha once and overlay it in a V track).
Doug Calhoun
Re: Timecode export
on Jun 18, 2009 at 9:16:27 pm
Thanks Floh, I'll see if I can set up an overlay in Compressor. I appreciate your input.
Gary Milligan
Re: Timecode export
on Jun 18, 2009 at 10:33:01 pm
I have a DVD recorder that I use for client approval purposes. They're relatively cheap these days. I use the analogue signal looped through my CRT monitor to feed the recorder, and then just play the timeline with the TC displayed. The audio is from an output on my Mackie mixer. The picture quality is obviously not as good as it could be, but for client approval purposes it works for me... quick and easy.
HTH.
Gary
This is me - this is what I do - http://web.mac.com/garymmw
Fermin Branger
Re: Timecode export
on Jun 19, 2009 at 12:58:10 am
Hi Doug,
You can export your PGM to XML and open it in Final Cut. Ther you can sellect Time Code Generator in Video Filters, an then export a Qtm movie or playback to some deck or DVD recorder
Fermin Branger
ALFARERIA CINEMATOGRAFICA
Caracas, Venezuela.
